JoLin
Thread starter- Joined
- Aug 18, 2007
- 5,146
1995 175 hp Oceanrunner (carbed)
A week ago I sucked a load of sand into the motor. The overheat alarm went off and the motor dropped into SLOW mode and I limped home at 2000 rpm.
I hauled the boat out, pulled the lower unit and cleaned out some sand. Impeller was fine and water pump housing was not scored. Found some grass up in one of the thermostats, so replaced them, too. The motor still overheated in the "tank."
At that point I pulled the heads, flushed 'em, cleaned sand out of one of the cooling passages in the block (it was the only one that had any junk in it), and carefully put it all together with new new o-rings, RTV sealant and a torque wrench. Started it up and the alarm went off again. i swapped out the temp sensor with an old one I had around and bingo- no more overheat alarm. (I do believe that the motor overheated when I pulled in the sand, but I also think the first temp sensor fried itself when it happened). Temp at idle (measured with IR thermometer) was bang on spec for both heads, and it had never been so close from side to side. Damn near perfect.
Everything was now fine in the driveway, so wife and I relaunched a couple days ago and took a long ride at our normal cruise speed (4000-4500 rpm). The motor never ran better, and even my wife commented that it was smoother at idle than it used to be. The motor has always run well, but it looked like the head job had improved things all around.
Today I went out by myself and ran non-stop for an hour at cruise. Motor ran perfectly. The bay was calm so I decided to open it up on the way back. After 5 minues at 5000+ rpm the overheat alarm went off again and the motor dropped into SLOW mode. I cut it back to idle speed, and after a few seconds the temp light went out. Back to 4500 rpm for awhile with no problem at all. Pushed it to 5000 rpm again and after about 10 minutes the same thing happened. Rode back home again (30 minutes or so) at 4500 rpm without a peep from the alarm.
Now, I seldom if ever run the motor beyond 4500, but it frustrates me that something is still not right. Any ideas, folks?
