flywheel puller
kwulff
Does anyone know where I can get a flywheel puller for older Johnson Motors? I'm using a homemade one and actually have a 3' long breaker bar on the center bolt of the puller and still the flywheel won't move Any sugestions?
iwombat
Re: flywheel puller
Go to any decent auto parts store and get yourself a "harmonic balancer puller".
Depending on what you're working on, you may need some 1/4-20 grade 8 fasteners to thread into the flywheel. They won't come with the puller.
Re: flywheel puller
like this,
jay_merrill
Re: flywheel puller
You also buy one directly from OMC/BRP. It comes with a variety of correctly sized bolts for pulling flywheels on various OMC motors, and has the required bolts for pulling one piece gearcases apart.
This package is a bit pricey compared to just buying a harmonic type puller at your local auto parts store, but it does save you a lot of hassle in making sure that you have correctly sized, grade 8 bolts for whatever you are trying to pull apart. I think I paid about $65 for mine about 7 or 8 years ago.
Re: flywheel puller
i would loose the bolts, or scavage them for another project.
lyncraft_mechanic
Re: flywheel puller
i have always built my own pullers and they have always worked well for me. try giving the flywheel a couple of sharp blows with a rubber mallet while using your homemade puller.
DutchMerc
Re: flywheel puller
I tried to take the flywheel of my 402 Mercury, and it gave me some trouble. I made a puller, put some pressure on the flywheel but no succes. I only got it of after i heated the flywheel (gently) with a toarch, leaving the tension on. Came off with a big bang... No damage on the stator and bearings. I put it back after greasing up the shaft. Good luck...:cool:
BillP
Re: flywheel puller
For the money you can't beat a harmonic balancer for flywheels. Approx $10 at harbor freight and buy a couple extra bolts to fit the flywheel if it doesn't already have them.
Re: flywheel puller
DO NOT hit the fly wheel with a hammer. you hit the center bolt of the puller. DO NOT pull the fly wheel by the outer edges.
