Re: 1990 9.9 evinrude submerged in ocean...for a long time
yep,what iwombat said,worse thing is letting it dry out.I salvaged many motors in South Fl. that sat on the bottom for days.Some actually got running ,how long they lasted ???But most are ripped apart.That engine is pretty simple,if you flushed with freshwater,drained carb ,cleaned the electronics including removing flywheel ,flushing,spray with electrical cleaner/dryer,get compression,spark,fuel,should run.Be sure to use 25 to 1 oil and run it for a loooooooooong time
