cooling question
fastrthnstock
i just removed thermostat and cylinder temp sensor and wow inside looks a mess, some sort of corrosion build up. is there anything it can be flushed or cleaned out with?
rubinjames
Re: cooling question
Scale from the water you run in. Might have to have engine taken apart and cleaned out if real bad.
Yamajoe
This scalely buildup will also be throughout your water jacket in the cylinder head, if it is bad, consider removing cylinder head and cleaning.
