Hi Everyone!
I am in the final stages of a complete rebuild on a V6 2.4 1986 V200 (200hp)
and I cannot positively identify the correct placement of all the bleed lines on this motor.
The Clymer Manual I have is not good enough as it has only a partial layout of one side of the routing pattern and it even mis-identifies the horizontal and vertical reed types.
My block has one fitting on each bore...(at the top sides, close to the heads)
one fitting at the block and crankshaft case per bore...
one fitting at the top and bottom of the carb manifold and one fitting at each of the other four carbs...
There are also fittings at two bores recessed between the cylinders, close to the "bottom" of the block (nearer to the cranshaft instead of the heads).
The hose routing seems logical for a few of the fittings...but I would rather have a positive guide to go by, seeing as I did not have a completed example to go by when I originally picked up this motor.
Ideally...if any of you have the Mercury Factory Repair Manual for this block...I could use a scan of the routing....the Clymer Manual has been pretty vague in many aspects and I am lucky that I can draw on my experience as an automotive mechanic to get most of the work done...but when it comes to two-strokes...well....this is something I do not want to guess at, as it means tearing out all the ancillary components on the motor to re-route these darn things if I get it wrong.
Also...is there any harm in using premium-quality CLEAR fuel hoses for all my needs on this motor? I am planning on using them for EVERYTHING from the quick-connect to the carb distribution lines. (this has always been a great comfort to me when I had old "beater" snowmobiles and saved me a ton of time whenever there was a running problem....
I am also planning on using clear, braided hoses for the cooling system and would also like your opinion on whether this is a problem...(once again..this is a way of ensuring all is well by simply looking at them)
Thanks in advance for your help, all...and if you are from my part of the continent....I wish you all a peaceful hibernation and look forward to enjoying my "new" Hydrostream and Merc in the spring.
