tachometer
Re: tachometer
Any aftermarket OUTBOARD tach will work on that motor, provided you have moved the brown wire from the switchbox to the AC side of the rectifier.
jason1150
Re: tachometer
found a 4 cycle tach, 4,6,8, cylinder, it has 3 wire hookup, send, ignition, ground, do you think it will work, thanks, jason
jason1150
Re: tachometer
even if I move the brown wire from switchbox to the rectifier
jason1150
Re: tachometer
I'm searching on ebay and I see all these tachs for pretty cheap, kinda hard to tell which one will work, any recommendations? thanks, Jason
Moody Blue
Re: tachometer
It should have a setting option for "poles". Could be 6 or 12 poles.
Try searching for marine tach, that will narrow your choices.
If the tach only has settings for 4,6 or 8 cyl it most likely will NOT work with your motor.
jason1150
Re: tachometer
found this one, says it's for a 2 stroke, don't know about the pole setting, think it will work?
Re: tachometer
If it has a 6C or 12P settings it should work for you.
jason1150
Re: tachometer
he says it will work for a v6 which is 12 pole so it should work
Moody Blue
Re: tachometer
That looks just like the Quicksilver tach I have. There is a selector switch on the back for 4,6,8, cyl and 12P. If it is the same as mine, it will work with your motor.
