'92 Johnson 115 V4... Temperature
Hachie
How hot should the heads be on a 92 Johnson 115 v4?
Should I be able to put my palm on them and leave it for a few seconds or 10 or what?
I think mine might be getting too hot, But i haven't heard my warning buzzer go off. It pees good and strong. So how can I tell if it's running at the right temp?
Thanks.
emdsapmgr
Re: '92 Johnson 115 V4... Temperature
Someone you know may have a laser gun for checking temps. The thermostats will open at 143, so expect to see temps between 143-150 on a summer day. The engine overheat horn will go off at 212 and silence when it gets back down to 175. There is a thermostat for each side of the block, so compare the temps on both sides.
Hachie
Alright... Sounds good... Thank ya'll for the help... Sounds like mine is about where it should be.
