Drilling fiberglass with hole saw
watchinthebobber
I need to drill a 1 1/8" hole in the fiberglass of my boat to install a plug receptacle. Can I accomplish this with a standard hole saw without problems? The fiberglass is about 1/4" thick. I've read about starting the hole with the drill in reverse to prevent the gel coat from chipping. Is that my only concern? Will the hole saw cleanly cut through the fiberglass otherwise?
The instructions for the plug just say 1 1/8" hole saw, but I thought I'd ask before I butcher something.
Thanks
marine4003
Re: Drilling fiberglass with hole saw
Yup..a hole saw is your best bet..if possible attach a piece of duct tape on the hull and mark your hole location on the tape..then drill,use a good quality NEW bit to minimize gelcoat damage.
drill a small pilot hole first, then start the hole saw in reverse to score the gel coat, then go to forward and cut it.
Tim Frank
Do you have access to both sides?
Drowned Rat
Covering the cut area with tape is a good idea to prevent chipping. Use the blue painter's tape for a best result. Duct tape is a little gooey and will stick to the saw blade and make a mess on your hull.
Old School
i just drilled 2 holes with a holesaw in my fiberglass boat and had no problems.....i didn't know about the"backwards trick"....and i didn't have any chipping, but i would try it, wouldn't hurt.
Moody Blue
In addition to the good advice already given I'd like to add that the backside of the hole will end up a little rough. Can't be avoided unless you can get to the back side and partially cut thru.
The other thing to know is to use a low speed and high pressure. High speeds and hole saws don't go good together. Use a dust mask, you'd be surprised at how much fiberglass dust it will create.
jay_merrill
I'll add another trick, If you ever have to enlarge a hole you will find it difficult, because there is no place for the pilot bit in the hole saw to drill into. Trying to place the large portion of the hole saw in the correct position, while engaging the drill won't work - you won't be able to keep it in place and will end up with a scarred boat, and a hole in the wrong place.
Instead, clamp or firmly wedge a thin piece of wood (1/4" ply or similar) to the area to be drilled. Measure carefully to find the correct center point, and start the pilot bit in the wood. The bit will then keep the hole saw in place, resulting in an even hole, in the location that you want it.
HappierWet
That's a pretty cool trick. It occurred to me, although I haven't tried it (yet) if you used a piece of plexiglass you'd be able to keep track of progress. Also less chance of messing up measuring.:)
plexi tend to melt, and gum up hole saw.
Beefer
watchinthebobber
I just wanted to report that this install was a success. The hole saw worked beautifully! I didn't bother taping the spot. All I did was run the drill in reverse nice and slow to begin cutting the gelcoat. Worked great and no chips at all!
I would like to post some pictures, but I've been way too busy.
mthieme
Thanks for letting us know how it turned out.
Glad it worked out for you.
109jb
You can use a hole saw on plexi without melting it if you know how to do it. You need to run very slow, clear the shavings periodically. You can also use a squirt bottle and cool the plexi and saw by spraying water on them.
Most people run hole saws way too fast. By slowing them down and periodically clearing the shavings the hole saw will give better results and last longer too. You can burn up a hole saw in a matter of seconds on steel if you run it too fast.
Fish~n~Chips
I think in general people use "all" drill bits improperly. Kinda like sand paper, works so much better when you do it right. Just my 0.02!
~Jason
