gas tank
kandil
Re: gas tank
Welcome to iboats most likely it will be under the CC floor you probably find a round cap access panel to the fuel sending unit the tank it self is sandwiched between the hull and the floor what are you trying to do?
shelbywilson
Re: gas tank
trying to find the sending unit. found it thank you how do i get this rusted bolts out of the sending unit?
Re: gas tank
Ayuh,...
Very Carefully,+ Alotta penetrating oil...
kandil
Re: gas tank
try an impact screw driver the kind you use the hammer with
maxturbo
Re: gas tank
I dont think he wants to use an impact driver cause u may cause a few sparks. And that might not be such a good thing when working around a gas tank.
Heres what I used on mine and I use on all rusted screws and nuts. Go to a local auto parts store and ask for valve grinding compond. Put alittle on the tip of the screw driver or socket and it will prevent it from slipping. ;)
