Re: Can you paint over truck bed paint
If you are talking about the Rhino liner type of paint, I'm sure you can if you can prep it properly. You'd probably have to use a liquid "Deglosser" to scuff the surface for a good mechanical bond, and you would probably want to add a flex agent to the paint so it resists chipping.
Are you considering using it in your hull, but want to paint it instead of being stuck with a limited number of colors?
