freddyray21
Thread starter- Joined
- Jun 10, 2006
- 2,460
1949 Evinrude 3.3 Sportwin. The gas tank has the original cap which to me does not appear to be vented. There is a vent tube on the port side of the motor. It is connected to a metal line at the tank and to a nipple on the carb. The carb has a mechanism where you turn the high speed mixture and it takes a rubber pad off of the vent nipple on the carb thus opening the vent. That is how I see it. The question is that unless this mechanism is left open the tank will not vent. At least that is how I see it. I have the motor running and pumping water well. I need to check the carb to see if there is some crud in it that I missed, but it occured to me maybe I don't have the vent right also.
