1985 70hp Johnson - HELP !!
boatman48
just got this boat/motor. it ran poor from the start. loads of water
in fuel seperator and did the following.
- dumped old gas
- replaced all fuel lines, from tank thru to carbs
- cleaned and rebuilt all carbs, including new high & low speed jets
- new spark plugs ( gapped correctly )
- new spark plug wires
- rebuilt fuel pump
- replaced one of 3 coils
- installed tach
- compression check ( all with 10 of 110 )
- checked timing, ( is it really just stop screws )
got boat to start well, idle well, run well up to 4000 rpms then it bogs down.
squirt pre mix into top carb at wot and motor would jump up to 5500 rpms.
same story with holding in primer solenoid. jumps to 5500 rpms.
- cleaned all 3 carbs again. this time soaked in mineral spirits for 20 mins
and worked them with a toothbrush. blew them clean with compressed air.
put it back together, started motor with muffs in driveway, a little hard to start but ran okay at idled to 2000 rpm for a good 10mins
took boat to water, backed it in, lowered motor in water. motor would
not start. waited 15 mins. shot some starting fluid into carbs, motor
started. ran on trailer in water for 10 mins, then pushed her off
and headed out. got up to 5500 rpms for about 30 secs, then she died.
got it started again, and limped in at 1500-2000 rpms. lots of coughing,
gasps and choking the entire way. anything over 2000 rpms she'd die.
my current thinking is, fuel problems are now solved but there is now
a spark problem. i have ordered a new powerpack and will install it
and test again this friday.
my question: - am i grasping for straws with the new powerpack, does it
really seem like there is a spark issue, what else should i look for, consider,
do or test ?
Dhadley
Re: 1985 70hp Johnson - HELP !!
Personaly I'd only opt for changing (expensive) ignition parts if I was sure it had no spark. But only after I ran the tests to make sure I was replacing the correct component.
If holding the primer in and / or squirting fuel into the carbs cures the issue I'd say you still have a fuel delivery problem. I'd start by soaking the carbs in carb cleaner. You say you installed new kits, we'll assume the floats are set correctly and are free. We'll also assume you didn't forget the round gasket over the emulsion tube.
You mentioned the water separator, have you checked it again for water / debris? Also make sure you have the correct Champion plugs.
noelm
don't wish to appear harsh here but as dhadley has mentioned, if you hold on the choke or squirt fuel into the Carby it runs OK (well sort of) so why do you come to the conclusion there is a spark issue? not saying there isn't but just think about it for a second!
boatman48
seems like my post was not completely clear. there was a 2 step process.
Step 1. Did everything listed, but soak and clean carbs with toothbrush.
Results were, easy start, great idle, runs fine to 4000 rpm . wot bogs, squirt pre mix or hold primer solenoid jumps to 5500 rpm. obviously not the way
she's supposed to run, so i keep trying.
Step 2. Soaked and toothbrushed carbs, hit 5500 rpm WITHOUT squirt or primer push for 30 seconds. then died and ran worse then ever, poor idle,
dies at anything above 2000 rpm, engine coughs, barfs, chokes, sputters.
thinking is, fuel supply problem now solved but now have spark problem.
Benny1963
sounds like carbs still picking up trash any time you introduce external fuel to carb and it picks up it means that your not getting correct supply
check your spark under load on trailer with timeing light
when the prob occurs you will see the miss by looking into timeing light
when you hit primer your motor should bog down not pick up sounds as if you have fuel prob run differnt tank and hose. bypass fuel filter if ya have one in line ,if that doesnt get it back off with the carbs pull welch plugs and jets
soak overnight , blow with compressd air , i know you have had them down a couple of times but sounds like you have restriction in jetting.
i pulled a carb five times with high speed bog finally took it to my boat guy
i sonic cleaned it and used compressed air with small tip on it
also had heavy float but that would cause over gassing on plugs what do your plugs look like
HybridMX6
I'm not sure he tried squirting gas directly into it after it died after he cleaned the carbs, since he doesn't say he did.
boatman48
correct, i did not try squirting gas into carbs after it died.
seemed pointless as the motor was just barley running.
anything over 1500 rpms and she'd die.
this behavior was brand new. before the soak it would
run fine to 4000rpms then bog at wot.
after the soak it ran for 30 secs at 5500 rpms then died
and would only do 1500
when it was running at 4000 rpms squirting only made
a difference in carb #1, that's why I opened them up
again and did the soak, thinking fuel starvation in #1
after the soak since it got to 5500 rmps without squirting
or primer switch on, i figured carbs are clean fuel problem
solved. then 30 secs later it died and i limped in
boatman48
Well I got the new powerpack and put it in. Guess what same problems
with a new twist. Now in addition to hard to start and running poor, I
can't get it to idle at less then 2000rpms.
So it seems my carbs or fuel supply are still bad. I got some berrymans
and will soak overnight to see if that helps.
The too fast idle has me stumped though. The butterflies on the carbs
are closed and idle stop screw is not even touching the throttle arm/plate.
Does anyone have some ideas to help me with the idle problem or/and
thoughts about the carbs still not working right.
Thanks, I eagerly await your replies....
boatman48
After more research I'm thinking the too fast idle
is either a big air leak or the idle circuit in the
new power pack is not working right.
When I got the new pack, the connection
pattern in one of the rubber boots did
not match the old one. Attached is a pic.
I doubled checked I had the correct pack then
choose to swap the boots. I matched
up the wires correctly and got it to plug
in with no problems.
Does anyone have some ideas for how
to check the new power pack ?
Thanks !
boatman48
Update !
I fixed the fast idle problem, it was the power pack. One of
the pins was bent a little in the rubber boot and not making
a good connection. I also put three new spark plugs in
and gapped them all to .035
I got her running great with muffs, then took her to the
water. She started fine and I took off, ran at WOT 5600 rpms
for a minute or so.
Then she bogged down, started to cough, sputter back fire,
slog, choke, etc.... anything above 2500 rpms and she'd die.
I tried some pre mix in the carbs during this and it made no
difference.
Anyone have a opinion ?
It would be great to hear from someone with experience.
This is my first boat and first time I've worked on a
a motor since high school shop class 30 years ago.
Thanks !
HybridMX6
I am not a mechanic, but if spraying pre-mix in the carb did nothing I think you can rule out a fuel delivery problem. Sounds more like an electrical problem to me.
If I'm wrong I am sure someone will correct me, and even if I'm right I am sure they will give more insight into what to check out and/or fix. I'm about as new to this as you.
boatman48
HybridMX6 - Thanks for the reply, I've been wondering if anyone has
been reading my posts.
I'm at the same conclusion you are, electrical. I'm thinking coil
or rectifier or something else, just not sure which and how to
test.
Does anyone agree or disagree or have a comment about how to test
or what else in the electrical area or elsewhere I should investigate.
Thanks !!
Big Bubba
Hello to you,
Is it overheating on you, maybe that is why it runs at 2,500 RPMs after it heats up. If not get a hair dryer and warm the coils up one at a time and see if heat is causing the coil to go out and thus losing spark on bad coil. Check your spark plug wires and make sure there good also no cracks, detoriation, dry rot etc. Also make sure your coil grounds are clean and shiney as well as all the gronds on the motor, nice and shiney clean. Hope this helps you out somewhat without having to buy pars and put them in to find out it is another part and waste money. Let me know, Bob:)
boatman48
Bubba - No idea if it's over heating or not. There is no temp gauge
so I have no idea about what the temp is. I don't even know where
the thermostat on the engine is. Can you tell me where that would
be located ? I'd like to inspect and see what it looks like.
The spark plug wires are all brand new, I will check for shiney grounds
plates on coils and the other grounds on the motor.
iwombat
I haven't seen any mention of a spark check. Did you do one? What did it show?
boatman48
i've done spark check where I remove a wire and see if the
engines acts differently, it does. i've also hooked up a timing
light and got flash on all wires.
if you are asking about the spark check where you test that jump
thing, i've not done that yet. I don't know how to do it, what
tools to use and what I'd be looking for.
can you tell me if that's what you're asking and if so, how i do it
and what it all means.
thanks !
iwombat
You should get spark to jump a 7/16" gap. You'll need to buy or make a spark tester. Plenty of info on that in the forum if you do a search.
Spark test is the only real way to test for healthy spark.
boatman48
if the spark is bad, then what ? i've done wires, powerpack, new plugs
and one of the coils.
iwombat
If the spark is bad, then you start swapping coils, and testing components. If it's healthy you move on to the fuel issues.
