New Motor, No prop! please help!
gmata007
I just bought a 1998 45 HP Johnson commercial series, i am planning on putting it on a 14' inflatable.
I have no idea what kind of prop to get. I am trying to order a prop online for this motor and i am lost, they range from 9" - 24" pitch propellers.
Any idea what do i need?
Thanks
Re: New Motor, No prop! please help!
12-1/4 x 15P or 11-3/4 x 17P cupped aluminum to start with. Should put the motor at 5500 - 5800 RPM with an average load. (Yes I know 5500 is the upper end of the band but the motor likes 5800).
gmata007
Would this prop Work for my boat?
Diameter 13-3/10? 17? Pitch :confused:
Thanks
Gary H NC
As long as it has clearance and the splines match up it should.
steelespike
Not an expert but my guess is that is intended for a larger gearcase.
Is it listed for your motor?
bowman316
Check out this prop exchange group, where you can network with other boaters, and post what type of prop you have, and what type of prop you want. There is a list of props that people want to trade, or sell. Check it out at:
http://groups.yahoo.com/group/propexchange/
gmata007
The Commercial Series has a Larger Gear case.
This is other option i have 13-1/2? 15 pitch, what would be better.
gmata007
Please Help! I need to buy the prop soon! i want to go use my new boat for the first time but i don't know what prop to get.
Basicly i found two props for a really good price here at iboats.com
SOLAS RUBEX 3 Blade Aluminum Propeller
Pitch: 15?
Diameter: 13-1/2?
or
Pitch: 17?
Diameter: 13-3/10?
By the way this is for a 14 inflatable, waits about 300 lbs plus about 700 lbs for people and gear.
Randybeall
Based on the light load and what Silvertip has to say about that engine (he knows) I would suggest going with the 13 1/2 x 15 prop. Quick performance and not bogging down the engine is important.
