luisdeleon
Thread starter- Joined
- May 23, 2008
- 82
before i buy new batt and switch i want to start it, anyone now how? it's a 77 35hp johnson
thanks
luis
thanks
luis
Be careful with the wiring. Any voltage at all riding the Black and yellow kill wire (large M post) will instantly destroy your expensive powerpack.
Any voltage at all in the wrong direction will instantly destroy the rectifier.
The switch wiring diagram above is incorrect for your motor as to the colors of the kill wire (large M), and the choke wire (C).
The harness choke wire is purple with a white tracer. The Starter (S) wire is white. The battery (B) wire is purple and red indicating a fuse.
Click the diagram for a basic view of the ignition wiring. Points two and three are the ground and positive wiring that activate the starter solenoid, allowing the battery power to flow through the solenoid, directly to the starter.
If you have the battery connected, you can activate the solenoid by taking power from the large solenoid post (6) to the small solenoid post (3).
Notice the fuse holder on the positive wire leading from the large solenoid post to the ignition switch.
The fourth screw on your terminal block should have a red wire that runs from the large post on your starter solenoid. It should be connected with the red wire from your rectifier. That is the wiring for charging your battery. Nothing else should be connected to it.
