PaulyV
Thread starter- Joined
- Sep 7, 2008
- 525
My 14' starcraft has a 1965 40HP Big Twin. Transom measures 15" motor shaft 18.5". ( I just purchased this boat)They built up the transom 2.5 inches with a piece of wood. Not sure why.The motor locks are 1" away from the top of the transom. There is also a metal bracket that the motor locks are tightened on to. What purpose is that? The 2 bolts you see below the motor mounts are not from this motor. The motor is not attached to the transom by anything accept the 2 screw clamps. This to me does not seem too secure but I was told it runs fine. Is this motor (shaft) to long for the transom? I am planning a complete restoration of the boat and want to replace the transom and make it its original height. By doing this the motor will sit lower in the water. Again I haven't been able to test her out so I am speculating. With all the experience here I am sure I will be led in the right direction.
