Re: 1st timer LOTS OF QUESTIONS !
Hi Bryan,
You asked...
Three questions for now.
1. Do I need to cut this transom as close to edge as possible & just rip the old plywood out?
2. The foam here in front does not appear wet at all. Should I leave it or tear out/replace or even really need it?
3. The stringer seems fine. no rot. Leave alone or continue cutting & replace?
Let's see... My $.02...
1.) Hmmm... The bottom line here is to cut away what needs to be cut away in order to rip out the rotten transom and replace with structurally sound stuff.
2.) If the foam in the front is really dry, and the wood looks good, let her be.
3.) As long as the stringers are good, leave them and sister as you need to. If it looks like they need reinforcing because of poor initial manufacturing, do it.
One of first things you might want to do is clamp 2 x 4 across the middle of the boat from gunwale to gunwale (or at least where the gunwales would be) to keep the shape of the boat such that the cap will fit back on. You can use the cap as a sort of template.
Small boats like yours only really consist of 6 elements:
i.)hull
ii.)transom
iii.)stringers
iv.)flotation
v.)deck
vi.)cap
Get those six elements sound and working in unison and you've got a functionally fine boat. Spend a little more time and $$$ and you've got a pretty boat.
Like I said... Just $.02
Alan
