Spivy30
Thread starter- Joined
- Jul 19, 2008
- 299
I just purchased a 1991 Glastron 1900 with a 5.0 V8 the boat is in great shape but the block is cracked. I guess a few years back the boat was improperly winterized and the block cracked in the rear of the motor. Well I guess the local dealer pulled the motor and fixed the crack, the previous owner didn't know if they welded the block or just fixed it with some expoxy but the block was not replaced. Well I guess this fix failed this year and it started leaking again(started leaking mid-season so I don't this it was improperly winterized again) I am thinking the crack is only external because there is no trace of water in the oil. Does anybody know it this is a common place for the block to crack? Is it possible for me to fix it with jb weld? Is there more I need to find out? I only paid $300 for the trailer and got the boat for free so If I found a long block or a complete used motor to put in I guess it wouldnt be that bad but I'd like to go the inexpensive route first. The boat has 600 hours so i'm going to do a compression check and make sure the motor is good before I decided anything. The previous owner said it still ran fine though.
Here are some pictures of the boat...http://s437.photobucket.com/albums/qq95/aspivek/1991 Glastron 1900/
