Re: Left or Right Level Line Reels
But I did see a lot of bird nesting. Trying to drag the spoil correctly seems to be a learned art.
Where you releasing line as you motored or casting?
If peeling line off the reel while you motor, set the spool tension with just a hair of resistance. This should keep the line tight on the spool and keep it from over running. If you are pulling on the rod to strip the line off, keep a light touch on the spool to keep it from over running. I normally set the rod in the rod holder and strip line off while motoring. But,,, if the spectra/mono (or lead core/mono) knot gets hung in the rod tip tip and creates a bunch of tension on the line, it will "
POP" out and create a nice backlash for you
Casting a conventional reel has it's challenges too, learning how much and when to feather the spool takes practice. I noticed you mentioned stopping the spool when the lure touches down, but you also have to ever so lightly brake the spool during the cast,,,, if needed,,,, and the right amount of pressure. Doesn't take much pressure at the right time to stop an over run.
You can also put thick oil in the spool bearings to slow down the spool and help prevent backlashes. I go the other direction for my casting reels and wash the spool bearings, then lube them with a product called Rocket Fuel, with a name like that you can only imagine how easy it is to get a backlash
