Stumped w/cooling problem
asp252
Recently bought a 76' Merc 110 (9.8 hp) and can't get a constant stream out the pee hole other than high rpm. Nothing but steam at idle. I first checked for blockages and found none. Replaced the water pump impeller and cleaned/resealed all the fittings and housing. Checked to make sure it worked before reinstalling lower unit by attaching driveshaft to drill. Made a nice fountain. Put it back together and started it up-still no water out of pee hole. Air easily blows through from pee hole end, so definitely no blockages. I assumed a bad connection of water tube at bottom of powerhead, so I removed the powerhead and cleaned inside of drive shaft housing and underside of powerhead and replaced gasket. The connection of the water tube seemed fine. Before reinstalling, I blew through water inlet port on the bottom of the powerhead while plugging the outlet on the top of the crankcase. Air was leaking out of the two little slits between the drive shaft hole and the exhaust area (see attached picture). When it is all together and I force water backwards through the system (without the lower unit attached), water leaks out of these slits. I can see it when I look up the through the drive shaft housing. Is this normal? Is there something wrong inside the crankcase causing my leak? Apparently the leak is significant enough that when the engine is at idle there is not enough pressure to get water through the system. All I get is air/steam out the pee hole. I don?t know what else to do. Suggestions?
Laddies
Banned
Re: Stumped w/cooling problem
Blowing air don't do anything for a plugged water system but then you already know that. Pull the power head again then the exhaust cover and water jacket cover the impeller parts are either in the exhaust jacket passages or the passage between the block and exhaust passages probably the latter of the too.
newfiez
I'm having the same problem with a 1985 9.8, except I replaced the water pump as routine maintenance, and ran the motor for about a month with no issues, and now I'm having the exact problem described above, except I get steam (with air coming out) and eventually spitting water.
newfiez
Ok, so I pulled mine apart today...I found when I replaced the pump, it came with a new plastic tube (sits between the top of the water pump, and the water tube to the motor). The OD of the tube was a little smaller then the ID of the water pump housing, causing it to slip out of place under water pressure. The quick fix (without replacing it), is to put silicone around the base of the tube before inserting it into the housing. Then drill a small hole (I used 1/16" drill) through the water pump housing, into the plastic tube and put a small screw in the hole. This will stop the tube from popping out. I now have a nice steady stream once again!
