wanna start motor
nick34
can i start an outboard without the lower unit bolted on???
JB
Re: wanna start motor
I suppose you could, Nick, but it would be a very bad idea. No water pump, no load at all on the engine.
Runaway and explosion would be a real risk and overheating with severe damage almost a certainty.
Yachtzee
I have done this when buying "junk" motors to see if they are at all viable.
On some old mercs at least you can shove the cut off end of a garden hose up over the water pickup tube that comes down out of the middle section of the motor. I have started and run them mostly at low RPM and for a short time. I would not rev them up much as they might easily rev off the tach without the load of the lower unit.
Try at your own risk
