Nautique93
Thread starter- Joined
- Nov 10, 2008
- 40
starts and idles fine, will run wot for a few minutes then lose power all the way down to idle, and will stall unless you take it out of gear. when it stalls it will start straight back up, will rev in neutral, idle in gear but give it some revs and it bogs down. seems like it happens once the engine warms up. the engine has good compression- 135 psi on each cyl. I have tried squeezing the primer bulb while the engine is bogging and it makes no differnece- although after squeezing it once it stays squeezed until you come off the throttle- so i assume the pump is sucking enough? The engine is a blueband early 80's 70 HP
