Marion Moore
Thread starter- Joined
- Feb 6, 2005
- 200
Model - ?96 Suzuki DT115STC (EFI)
Symptom ? Engine runs rough, idles poorly, and runs with reduced power.
Found - # 2 spark plug is fouled all others look normal.
I need your help in confirming the troubleshooting that I have done and determining if my results are correct. I believe the # 2 cylinder output from the Engine Control Unit is bad, here is why.
While running I removed the # 2 spark plug wire, no change in idle. I then removed the # 3 spark plug wire and the engine ran very rough. Same when removed # 4 spark plug wire. I removed # 2 again and no change.
I swapped the starter coil with # 2 and # 3. Same results as above, removing # 2 spark plug wire had no effect on the idle.
I swapped the spark plugs with # 2 and # 3. Same results as above, removing # 2 spark plug wire had no effect on the idle.
I attempted to do an ECU output test but I don?t have a CDI tester or a Stevens peak voltage tester model CD-77 requited by the shop manual. I used a Simpson 250 connected in line between the # 2 starter coil output from the ECU and starter coil. I was looking for greater than 104V but could get no meter deflection. I moved to the # 3 cylinder output for a reference but could not get any results either. I?m either doing something wrong or this is a shop test that needs special test equipment.
I did not have time to do a compression test last night. I have not done a spark test but could not find any other components that might cause the # 2 cylinder only to not fire. This is why I think the ECU is bad. If I am correct I will need to locate preferably a used ECU given the cost of a new ECU ($1750) is over half of the value of the engine and may not be worth replacing. Any help would greatly be appreciated.
