Can I take the electric start components off to drop weight? I plan on just using the manual start.
The 14' jon should scream with a 20HP. 10# is nothing in added weight. Leave a cooler home and you have made up that difference. Rick
I'm pretty sure the ring gear bolts on,There may be associated heavy cable and associated wiring and connectors present,solinoid, starter and 2 mount brackets,various bolts.Probably adds up to 10 lbs.
