please help
stackem
ive just bought a 1973 20 hp johnson but i get no spark the coils are new , i cant seem to get the flywheel off to check the magneto.. or brushes i used a wheel puller to try and pull the flywheel but when i do this it wants to strip out the threads... any pointers on how to get the flywheel off?
Gary H NC
Re: please help
Make sure you use grade 8 bolts into the flywheel...or are the holes already stripped?
stackem
Re: please help
the bolts started to strip and i stopped before they stripped out
HybridMX6
Re: please help
Do you have the right bolts? I recently had to pull my flywheel off (different year and hp) and got the puller from an auto parts store. They sold me the wrong size bolts for the flywheel, and I almost ripped my threads out too. I ended up having to go somewhere else for the bolts.
I also know this is not recommended, but I had no choice, but as I tightened the puller to remove the flywheel, it wasn't budging. I had to use a rubber mallet and tap the edges to get it to pop off. I was as gentle as I could be, but otherwise, it wasn't moving.
Probably a dumb question, but you did remove the flywheel bolt on top, right?
I had to sort through my mixed bolts at home to find the right size for mine, then go to the store with it to match it up with.
Gary H NC
Re: please help
Get the harder steel bolts and thread them in as far as possible.Try again.
stackem
Re: please help
i did use steel bolts but they want to bend or strip is there a cowter key or something holding it back from moving
Gary H NC
Re: please help
Yes,but are they grade 8 bolts? Should not bend...
david_r
Re: please help
are you using a standard crows foot? (steering wheel/damper puller)
ive seen people try using the puller upside down and bend bolts but not very often when used with the flat side up.
you will need at least grade 8 bolts or better........if you strip a hole youll have to retap the threads
hawkerjv
Re: please help
Maybe getting the flywheel off is not the first step. Does your motor have a stop button? If so have you disconnected the switch from the system? A shorted switch or shorted wiring will prevent the magic of the spark.
Jim in Wisconsin
steelespike
Re: please help
As suggested check the kill switch circuit then::
Grade 8 bolts,leave flywheel nut on loose to protect the threads tighten the puller bolt good and tight hold up on the flywheel and wack puller bolt with a hammer.re tighten and wack again repeat as necessary.
James R
Re: please help
Steelspike is correct. Try putting the puller under tension then smack the puller center bolt on the top with a hammer, Works most often.
tx1961whaler
Re: please help
1/4"-20 tpi, Grade 8 bolts with a harmonic balancer puller does the trick. You can carefully use a hammer or mallet to tap the flywheel once the puller is tightened down. Don't get carried away with the hammer. If you crack the flywheel, you might not find out until much later when it flies apart at 3500 RPM.
samo_ott
Re: please help
Keep cranking on the center bolt. It'll pop and scare the ^&%$#^&%$# out of you when it does!
mudslinging79
Re: please help
i picked up some grade 8 bolts at home depot. i went with an allen head so i dont get them mixed up with the regular bolts. as for the popping it with a hammer, i recomend a rubber mallet or a deadblow hammer, brass if you dont have any mallets. also try dribbling a lil penetrating oil down the shaft and let it soak for a day to help loosen things up and grease the way.
