Hello everyone, I am considering buying a late 1980's Wellcraft 233 eclipse (asking $5000). The cabin and outer hull are in generally good condition. The engine was replaced as well as the stern drive two years ago or so. I would buy this boat but I am hesitant because of two soft spots in the floor. Here are some pictures:
The two soft spots are under the seats on the left and right of the engine. Obviously I won't know the extent of the damage until I remove the wood. Couple of questions. Does anyone know if someone sells a plastic or fiberglass replacement for the engine box? I really don't like the wooden box that is on it right now.
If I replace the flooring how can I fix it so this doesn't happen again? Should there be drains there? Should I replace the seat cushions so there is one large one?
Lastly the owner says he replaced the carb a few days ago with this one. It appears to be a Edelbrock 1409, can anyone confirm?
That is not damaged wood on the right side, it is insulation foam that is chipped.
