reelfishin
Thread starter- Joined
- Mar 19, 2007
- 3,050
I was wondering when they made it mandatory for manufacturers to use flotation foam?
I cut up a 1964 Sea King today that got hit by a car, there was no foam, only trapped air space below the deck, as well as no wood stringers, only glass tunnels. The transom was wood.
I also cut the deck out of a 1966 Aerocraft last summer and replaced the deck and found the same design with no foam, it was another boat with dual bilge plugs, on above and one below the deck. I've also got an earlier, I believe a 1962 or 63 Sea King with lapstrake sides, with an all glass lower hull and no flotation other than a huge chunk of white polystyrene glued up under the bow ahead of the dash.
I guess another question is when did it become common practice to use pour in foam or when was it first used?
So far its been my experience that the boats built sans the pour in foam mess seem to all hold up much better. I'd gladly take my chances and add above the water line foam if able.
I do seem to recall reading somewhere or being told by someone that under 20' needed foam and over it wasn't required but wasn't sure when that was supposed to have started. From what I've seen, every boat I've worked on made after 1968 and under 20' so far has had foam. I've had a few newer boats over 24' that didn't have any flotation. Boats older and under 20' have been pretty random.
