merc 225 opti. ignition switch cause bad running??
oonighttrain
i have a 2000 merc 225 optimax. ran great last week.. the ignition switch seems to be somewhat faulty. it takes numerous cycles of the key for the engine to actually turn over. then, when it does, it runs like crap.. can the bad running be linked to a bad ignition switch???
or, can a low battery cause intermittent starter engagment and bad running??
thanks for any input!!!
oonighttrain
Re: merc 225 opti. can a bad ignition switch cause bad running?
by the way, it just had a full service including plugs and fuel seperators..
jimg984
i would check all grounding this is as important as the hot feeds
gotta have a good ground on all been thru this
oonighttrain
Re: merc 225 opti. ignition switch cause bad running??
please see revised post..
