I just changed the impeller on my motor. Everything seemed to go ok but now the motor smokes a bit and I am not seeing any water come out the p hole.. Water is coming out of the bottom.. Before the impeller swap it had very little water coming out.. I only ran it for a couple minutes and I think I flooded it first.. I installed the impeller the same direction the old one was installed.Looking down it is clockwise.. Did I do something wrong.. I also changed the lower unit lube... Thanks
Roger
Roger
