stevelaunius
- Joined
- Nov 29, 2008
- 7
I have a 1990 omc 2.3. I have checked and i am getting water to the motor from the outdrive. I pulled the thermostat out to make sure it wasnt sticking. I am at a loss. I can start the boat it will run fine under 2000 rpm. as soon as i throttle up it starts getting hot. i can pull the hose off the intake manifold and it cools down. but when i pull the hose off i have water coming out the intake and the hose from the thermostat under pressure. after i pull the hose off and it cools off i can run it all day under 2000 rpm. even in neutral above 2000 rpm it gets hot. thanks for any help.
