1996 Stratos 258
Jango
I would like to get the specs on a 1996 Stratos 258 such as:
1. Length at centerline
2 Beam
3. weight w. 90 hp Evinrude(also max HP)
Any other facts available would be appreciated - Thanks
LubeDude
Re: 1996 Stratos 258
Beam: 84
Dry Weight: 900 less engine.
Horsepower max: 70
Fuel Capacity in Gal.: 10
Livewell Capacity in Gallons: 12
Rod Storage Max. Length in feet. 7'
Propeller Pitch: 17P
Model: 258
Year: 1,996
Length: 15'8"
Jango
Thanks for your reply LubeDude. I found my Boat is a late 96 and follows the specs for a 97
Beam :74 inches
Dry weight Hull only: 905 lbs
Max HP: 90
Fuel cap gal: 18
Live well (2): 17.6 gal tot.
Propeller Pitch: 21 (4 blade Renegade)
Model: 258V
Year: Late 1996
Length: 15' 6"
LubeDude
Glad you found what you needed!
So, they made it shorter and narrower and rated it for a larger engine????????????????????????
Jango
I believe, according to stratos, the 258V was always the same dimensions with the max HP changed to 90 around Mar 1996 near end of model year (June). Prior to purchasing the boat on 12/9, I was getting conflicting info on Max HP and was concerned about overpowering.
