Re: Submerged engine
I have a different point of view.
I am getting an engine back up and running and went with the new rings and bearings while it was out, not because I was sure I needed them, but because the cost of gaskets and seals and renting an engine hoist all add up enough that I don't want to do it twice.
Cam bearings are the most delicate of the bunch and can be easily damaged by chemicals.
Once it is fully disassembled, the minimal costs of replacing the rings and bearings is cheap insurance. Clymer double roller timing chain and sprockets are only about $30 bucks and a new melling oil pump is priced in the same range (Though oil pumps do seem to be nearly bullet proof, I replace them out of an abundance of caution, cause they are cheaper than the costs of gaskets if they turn out to not be good.)
Rod and main bearings may be reused if they look good, but I would not reuse rings, they are too cheap. Once you clean up the cylinder walls, new rings will seat properly, the existing ones . . . Who can say? Cam bearings are hard to inspect, so I would at least replace those.
My 88 Mercruiser 5.7 had a single roller timing chain, a $30.00 upgrade was worth the extra effort in my opinion.
