Re: continuity tester
You want to use a voltmeter or test light, rather than a continuity tester for this job.
Go buy yourself a digital meter, even a radio shack, home depot or harbor freight unit will work. Every handy boater should have one.
Test Power at Switch:
1)Set the meter to "DC Volts"
2) Start at the electrical panel. With the wiper switch ON, place the red test lead on the output of the switch, and the black lead on the buss bar where the negative leads connect (wires should be black or yellow)
3) If you get a reading of 12ish volts, the switch is good, and supplying power.
4) If you don't get a reading, the switch is not supplying power.
Test Power at motor:
1) Leave the switch on.
2) At the wiper motor, touch the meter's red lead to the positive lead from the switch (should be red) and the meter's black lead to the black wire from the motor. Color here isn't too important, most meters will just display a negative "-" sign ahead of the voltage number if the leads are backwards.
3) If you are getting a reading of 12 volts, you have power up to the motor, and it's bad. If no voltage, check your connections/wires.
This assumes your motor is single speed - just on or off.
