Controller for 86 Johnson 150HP VRO
welljim
1st Post: Hope somebody can help me. I need to either rebuild or get a new controller for my outboard listed above. Can it be re-built? Which parts will I need to replace? The controller when shifting throttle from low speed to full thottle there is a lot of space between low and high. The speed is no varible goes from slow to high speed only when throttle is pushed as far as it goes forward. Thanks for your help Welljim
james williams
Re: Controller for 86 Johnson 150HP VRO
If that is the only problem,buy a `hotfoot`.
are you sure the problem is in the control, it could be in the cable, or the throttle linkage.
