56 Crestliner and 25 hp Johnson help
Status
Not open for further replies.
azfishnut
I just finished this project, or so I thought a couple of weeks ago. One of the things that I noticed was that there was alot of spray and it struggle to get up on plane. I thought that it was because of the extra weight from adding the fishing deck. A friend of mine that is a fellow boat nut pointed out that the cav plate looked pretty low in relation to the keel. Upon further research I discovered that the cav plate was almost 3" below the keel. Because I lacked the transom height to raise it, I rebuilt the top of the transom to bring the cav plate even with the bottom of the keel. I haven't had a chance to test it yet, but I will be taking it out this weekend to see if that improved the performance at all. The last run, it struggle to get above 13 mph on the gps. From my understanding, this old girl should clip along at about 25 mph. Would a different pitch prop be a good idea as well? I have a 9 x 10 on there now which I believe is what came with the motor from the factory. I should mention the motor is a 1969 2 stroke. I would appreciate any input on how to improve the performance on this old girl.
jasper60103
Re: 56 Crestliner and 25 hp Johnson help
Welcome aboard.
There's a lot of good helpful folks and info here.
I think you may get more attention about the motor issue on the Johnson Evinrude outboard forum.
ooldschooll
The only way to get 25 mph out of a 25 hp is to ride on top of the cowling and take it off the boat:D.
azfishnut
Welcome aboard.
Thanks Jasper. I copied it and moved it over to that forum. Much appreciated.
jbjennings
I get about 27 mph with my dad's yamaha 25hp on a medium guage 14 foot aluminum boat (gps measured), 26 with my '53 johnson 25 and '54 evinrude e-start 25. I find it perfectly normal to get 25mph with a 25hp outboard. I also get about 24 or 25 with my late 50's 18 hp outboards using a gps.
Just my observations,
JBJ
duplicate in Johnson forum.
Status
