seakayaker
- Joined
- Dec 12, 2008
- 2
Okay, you should first know that I know very little about boats. I have a boat that my cousin started restoring, did a great job, till he ran out of money. I bought the boat to help him out, and although it was not completed, we both thought it was to the point that it could be used. He had done a ton of work on the boat, and had the motor running like a dream, and, in the back yard, the prop moved as expected when put into gear, both forward and backwards.
A couple of weekends ago, I put it in the water. It was a little (okay, a lot) cold natured, but once it started, it sounded really good. Unfortunately, when I pushed down the throttle to back up, it didn't go any where, then cut off. after a couple of attempts, it turned over again, I manually turned it around, and tried to go forward. I engaged the throttle, the engine sounded like I should be going like a bat out of hell, but I was just barely moving. I went about 50 ft, really slowly, I throttled down, and the engine cut off. It wouldn'st start back up, but I think that had to do with the battery, as by the time I got it started the last time, it was showing signs of being drained.
I called my cousin. We thought about the possibility of a shear pen. I pulled the cone nut and found something that I thought might be a shear pen, but it looked undamaged, besides, there was splining on the shaft and in the prop, meaning that whatever that pen is, it could be broken, and the shaft would still turn the prop. We then thought that it might be that rubber pressure gasket thingy that is supposed to slip if the prop hits bottem, so it doesn't damage the gear box.
I took the prop off and ran a screw driver through the hole where the pen normally goes. I attempted to twist the splining out of the prop itself. I put more pressure on the prop than water ever would. The prop didn't slip at all.
Then I put the prop back on, and engaged the throttle w/out turning on the engine. the prop would only turn an inch or two before locking. I again tried to turn the prop as hard as I could. It wouldn't budge.
Does this not mean that the gear box is still in tact?
So why was I not going any where when I engaged the throttle.
I'd appreciate any help.
Thx, Rich
Thx, Rich
