Re: cooling buzzer
If you disconnected the single bullet connector in the tan wire to test the horn and you grounded the wire from the sensor, you grounded the wrong wire. You need to ground the other end of the tan wire (the one from the horn. The overheat sensor is just a switch. If the tan wire was disconnected that part of the ciruit had nothing connected to it. If you did NOT disconnect the connector in the tan wire, then you very likely have a bad horn. It is an electrical item and Yes -- they can work one minute and not the next. Light bulbs burn out and so do horns.
