Rocky_Road
- Joined
- Oct 8, 2008
- 1,798
Re: sd memory cards?????
Wow...we are typing at the same time, and crossing over the converstaion!
It is NOT the card...any one, or brand, will work in your H20.
It is just that as soon as you insert a card, that card overrides (takes over) the GPS mapping...this is true of any brand GPS. If the card you install is not a full fledged mapping program (read: Freedom Maps, Nautic Path, Hot Spots), then any additional info that you have added to that card, will be gibberish...and your basic built in mapping will be disabled.
okay so which is the best deal?-----navionics, freedom maps, map create,etc....?
i doubt ill use it in more than 4-5 local lakes----all of which i found on the free maps offered by lowrance................i bet yall are all thinkin you can hear me squeeking when i walk:.........im not usually this cheap but i have other fishing stuff i was gonna get with the rest of my gift cards.
i have also downloaded the GDM6 and EasyGPS and cant get them to use/open the free mpas i found either.
the thing that has me puzzled is that even when i erased and reformatted the card (completely empty) it did the same thing as when i had maps on it...........i thought i could at least drive around out in the pasture and mark some way points and save the info on the card--then put it on my computer......you know to get the hang of using it-----but it wont even let me open the menu while the sd card is in it.
the wife keeps telling me someone on here is going to tell me they had the same prob and that the card isnt compatible.......it is for a kodak digital cam, but it fits perfect![]()
