78whiteorbs
- Joined
- Nov 13, 2008
- 138
Well, I am posting some photos of my journey into this engine for anyone that might could use them there own voyage into the abyss.
Went to Northern Tool last night and got a impact driver for $12 and it was money well spent. Works great with a can of pblaster penetrating oil. This makes all those old phillips head bolts on old Johnsons easy to deal with.
I pulled the flywheel of with some effort and felt like I had ripped the beating heart out of a mans chest
Next the ignition plate came with the magnetos looking to be in perfect shape I believe from the looks. I think these are not original and someone must have replaced them at some point but can't be for certain. I have removed the carb and fuel pump and the casing behind the carb just to take a peek. Looked nice n clean in there . Now I am kinda at a fork in the road, I want the inspect the upper and lower bearings but do not know what needs to be removed next. I have some parts explosions from a '57 and '58 35 seahorse which is similar in some ways but not exact. After I can inspect the Bearings I think I will buy a seloc manual or somekinda pdf manual someone has compiled with lots of info on older Johnsons. This is the second outboard I have worked on by myself . The first being a Mercury mariner 4HP which was tiny in comparision. I put it back together and it worked better than before (that's how it's suppose to go
) and that gave me an interest in working on outboards. They are very manuverable to work on and pretty simple mechanically speaking,so they say! Plus with these old OMC's they can be cheap outboards if you find one mainly in need of tuning and minor rebuilding as I have read. I am keeping a photo record of all my surgical procedures here so maybe it might help another newby like myself and in case I forget what goes where I can just consult with the photos.
I already removed the recoil starter and before I did that checked for compression.
Question how do you attach a file directly into the message body as I have seen in alot of other posts?
