Re: help with Bayliner model identification
I'm always amazed at all the different hardtop models that Bayliner produced. Now I think all they have in a hard top is in the Discovery series. So if you do get it fixed up, it will be rather unique.
It looks like it has an outboard bracket attached to the transom. I would guess that boat came with an i/o (v8 inboard, with drive unit sticking out the back). Some people switch over to outboard(s) when the i/o's go. Some more pics of the transom will help determine that.
Before you spend a lot of time and money on it, you need to determine the condition of the boat so you can decide how much work and money it will take and even if you want to do it.
Check the floors for soft or rotten areas. If its hard, drill holes with a 2" hole saw and inspect underneath. Look in the bilge and inspect with a screw driver or ice pick for soft and rotten wood. Same with the inside of the transom. Chances are the floor, stringers and transom are rotten from sitting uncovered.
Go to shareaproject.com and look at some of the boat rebuild projects there. Especially check out "project long haul" which is a full floor and stringer job on a Bayliner Capri. Gives you an idea of what is involved.
Good luck. Post some more pics, especially inside and cabin.
