carb adjustment for 75 50hp
tchslemur
I have a 50 sizzler that had some idling problems after cleaning out the carb and i was wondering if anyone knows what the right adjustment is supposed to be for it.
just so everything is in the same place its a 1975 evinrude 50 sizzler
Benny1963
Re: carb adjustment for 75 50hp
welcome to iboats there are a buch of post on idle adjustment
if ya have manual you may go thru that section.
if ya dont ya may want to pick ya one up,oem is the best.
someone will come along ,i have had a couple of 50 1972 and 1973
dont remember what they were inital ,
did you remove and clean the fixed high speed jet, that is deep behind the bowl drain screw. if not you wasted your time.
(Carburetor Adjustment - Single S/S Adjustable Needle Valve)
(J. Reeves)
Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
Note: As a final double check setting of the slow speed valve(s), if the engine has more than one carburetor, do not attempt to gradually adjust all of the valves/carburetors at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve/carburetor. It may be necessary to back out "all" of the slow speed adjustable needle valves 1/8 turn before doing this final adjustment due to the fact that one of the valves might be initially set ever so slightly lean.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
