Hull Cleaner
prh3
I have a Pro-v 1900 Lund which has a painted aluminum hull. Does anyone know of any miracle cleaners or secret solution that I can use to get fresh water growth and scales off easily without eating the paint. Every brand and type of hull cleaner I have found says do not use on painted surfaces and are usually for fiberglass hulls and contain some type of acid. Any tips, tricks or recipes would greatly be apreciated.
THX prh3
Bob_VT
Re: Hull Cleaner
Simple green, elbow grease, water and sponge.
GO OVRIT
Re: Hull Cleaner
Vinegar should be safe. I usually cut Purple Power in half with water and spray it from a garden sprayer. If you work quick and don't let it dry, you should be fine. An automotive tar and bug remover might work good too.
JaSla74
Re: Hull Cleaner
Just avoid a scour pad unless you want a scuffed finish
BoatingCop
Re: Hull Cleaner
Wow! That stuff looks to work really well. I wonder if it will clean out an oily bilge.
