Good VHF radio?
strokeoluck
I've been reading that I should have a VHF radio in my boat even if I have a cell phone. Even though it sounds like most people don't ever use the VHF, it's necessary. We'll only be boating on small inland lakes (well, possibly Lake Minnetonka in MN which is a good size lake).
What's a good, basic VHF radio that we should purchase?
Are these relatively simple to install?
Are they powered by the batteries? (Just wondering how I'd hook it up)
Thanks!
dave11
Re: Good VHF radio?
I've got an Icom M34. It floats. It is a handheld set you can buy for about $150.
Boatist
Re: Good VHF radio?
If VHF is in use in your area then it is much better than a cell phone, but if no use in the area then the cell phone is better.
Personally I would suggest the first radio should be a fixed mount radio if you have a 12 volt battery on board. You should also install a good antenna.
With 25 watts and a good 6DB gain antenna the range is about 5 miles over water. So Boat to boat over water range about 10 miles. To a land station like the Coast Guard with a high mounted antenna the range can be 80 miles.
Most hand held with 5 watts good for about 2 miles.
Why a VHF is better than cell phone: If your out on the water and are sinking or on fire who can you call on a cell phone to help you? You can see several boats 1/2 mile away but how do you call them on a cell phone?
On a VHf everyone is required to monitor channel 16 by rule. Some will not but most will. So your sinking or on fire. You pick up the Mike and call MAYDAY on channel 16. Give your postion and decription of your vessel and nature of your distress. Boats you see 1/2 mile away will here you and the boat in the Tullies 200 yards from you that you did not see will here you. Coast Guard may also here you and send a boat with a fire hose and big pumps to pump the water our.
ziggy
Re: Good VHF radio?
i boat on inland lakes and the missouri river. i got a fixed vhf. it wasn't hard to install. just plan your drill holes carefully for mounting.
this is true. in the 2 years i've had my vhf. i've not transmitted once. i've also not heard much chatter come from it. some though. mostly from the uscg when i'm on the river. i got it mostly for river runs as more folks seem to have vhf on the river as you can be pretty isolated on the river at times. i had a incident this last summer on the lake though. i wanted to use my radio, but since there was only one other boat out in the high winds that hosed me, it was useless. the other boat was a sailboat, my distress was being beached so bad i couldn't get off myself (blowed up on the beach). i did get help, with a cell phone, though it wasn't instant help. if others would have been around, i think i'd have transmitted a pan pan.
i still like the idea of having it though. any communication devise that you can have when yer in trouble is comforting. i do like getting the weather channel too.
l went with the fixed for the better range.
as for a good radio, i wanted a icom. but they were kinda pricey. i ended up with a uniden oceanus that came as a package with a shakespear antenna. from what i get, the better antenna ya get, the better off ya are. the package i got didn't come with the better antenna, but for the use it gets, i feel i was satisfactory for the type of boating i do.
strokeoluck
Re: Good VHF radio?
Thanks guys. I'll start looking into some options.
By the way, how do you guys get those "below the line" statements/quotes to appear as part of your standard signature on all posts?
strokeoluck
Re: Good VHF radio?
Never mind on the signature...I think I just figured it out.
