Re: Sudden computer freeze...and barely reboots!
I'll usually remove the CPU fan and toss the 'bubble gum' factory heat sink tape or compound and go with my own thermal paste. Most folks think that if 2 aspirins is good , than 10 is better. This is not he case with thermal heat sink compound, don't over do it, very thin even coat. I clean the CPU and cooler with Acetone before the new compound and make sure cooler fins are clear.
You can do a Control-Alt-Delete and run Task Manager too. Look to see if you have any processes eating up CPU cycles and taxing your system.
Just some random thoughts......
