smokin_dodge
Thread starter- Joined
- Dec 30, 2008
- 18
so i did a compression test on a 1979 johnson 140 im working on. i was reading around earlier and found that all cylinders should be over 100 psi and no more than 10% variance. well today here are the numbers i got.
in cylinder order from 1 to 4
1. 70psi
2. 80psi
3. 75psi
4. 90-92psi
to get these numbers i took all the spark plugs out and placed the tester in each sparkplug hole from 1 to 4 and turned the motor over 5 times.
since my numbers are so low, what does this mean for the motor. i was already expecting a semi-rebuild, replacing a few parts, rebuilding the carb, etc. but with low compression should i just junk it or will be along the lines of a full rebuild?
1. 70psi
2. 80psi
3. 75psi
4. 90-92psi
