junkyardwarrior
Thread starter- Joined
- Sep 28, 2008
- 40
1987 model I believe (serial 0B132734)....
Starts ok but will run on one cylinder for a while, then it will take off & run on all 3. Seems to be worse in cooler weather. Sometimes during the summer it would run fine. Seems to only do it when the engine is first started-after it is run for a while, it will start & run every time on all 3 cyl. DOes this sound like a switchbox going south?
Also-I can't get it to idle down below 1300 RPM. Manual says 700 I believe? I have adjusted the carb every which way from Sunday and I can't ever get it down that low. Always wants to die? Any ideas?
Last question-I need a water pump. It works but pressure is getting low (~5psi wide open, used to be 10-12). It's been a while since it was replaced. Based on my serial number, I can't find complete kit (housing and all). Does anyone know where I can find one?
Last question-how much does this motor weigh? I have my eyes on a new 90 HP Yamaha and I didn't know how much weight difference there is--if any.
Motor is mounted to a '87 model Tidecraft bass boat-I like the boat (too small but I still like it) but this motor is just giving me fits.
