i dont under stand......why not do it right.
the poly resin and csm are 20 bux more than a bucket of spar varnish....thompsons waterseal or other,,,,, that may or may not work. (if you read alot on these forums.....there is really mixed results).
to "glass it"....the time factor is plus 5 minits work. application is the same.....(you basically paint it on).........however..... glassing will only require one coat both sides......as compaired to 3 coats spar varnish.....dry time with glass is 45 mins max.....spar varnish with 3 coats could be as many as 2 days depening on location..........
so.......its better time wize to do it right......the cost factor is possibly 20 bux....most likely less.
...I bought the clear satin helmsman spar urethane...it might be the same as the marine one as mentioned not sure.....
I bought the clear satin helmsman spar urethane...it might be the same as the marine one as mentioned not sure..I do know they don't make one that says marine spar...atleast it's not on their website or in your normal stores....
Yep plywood and white oak would be correct. Plus the small hunk of wood is fir or pine 2x4. The plywood appears to have mold on it. Unless you dont like the look of the oak, leave it or snad it. It appears to be in good shape other than exterior discoloration.
I would use pressure treated and glue your carpet to it. No need to do anything else. You could do the exterior grade, howver that wont be as durable as the pressure treated. The exterior grade is designed for short term exposure, typically until it gets covered with another material, like siding or roofing. Pressure treated is designed to withstand direct contact with the elements, including earth.
