Firstboat23
Thread starter- Joined
- Jan 8, 2009
- 30
Ok i finally got my motor running
after doing severall diagnosticts to find that my rectifier assembly was bad (is now removed till I have money for part 49.99) rebuilt carb / working great.... now i have figured out how my primer solinoid works externally..lever position ect. and how to use my cold start lever and key to prime it works then. ok here it goes! got motor started and wants to cut out in runn position if i turn slightly to the side motor runs ok put back in start position wants to stall noticed that there was a small bead of gas that shows up when i push in key then while motor is running sucks it back in and push key bead of gas at lever where it goes in repeated stays running ...well missed a push and motor went to backfire and lever poped up like a turky timer now i am heree ? any thoughts ...
