Sea Raider I
Thread starter- Joined
- Nov 23, 2008
- 113
Gentlemen,
I recently had my heads rebuilt (5.7 Mercuruiser 260) and went out for the first lake test today.
On the muffs, she fired up and ran great I tuned her and got the timing set correctly. She ran for an hour with no issues, very smooth throttle response.
On the lake however; she fired up and ran just fine. Took her up to plane with no problems. She ran great for about an hour UNTIL, the loud knocking noise that slowly starts up. Back off throttle and knocking continues with rpm range.
Anticipating trouble, I remove the valve cover on the lake and find #2 exhaust rocker very loose. BTW I followed the valve lash adjustment procedure to the tee...
I tightend down the loose rocker and started her up, noise gone.
Hoping for the best, we got her up on plane once again and within 10 min KNOCK< KNOCK etc....
Pissed.... I removed both covers and tightend em all down a little bit. Went to fire her back up and of course she wants to runs terrible ..... I figured I mis adjusted or overtightened some valves causing the rough running motor. We limped her back in.
My question is this: Is it unheard of to use locktite on these rocker nuts? Why would it persistantly spin loose?
I have already replaced the slightly bent push rods....
All Opinions Appriciated!!!
