Tonight I noticed some water spots on the ceiling in our basement. I knew right away it was from condensation because there were several little spots all kind of grouped up.
The basement is about 80% finished with an unfinished utility room running just about the entire length of the front of the house. The ceiling in the unfinished part is open to the rest of the basement finished ceiling space (does that make sense?). The furnace is in the utility room and keeps the utility room pretty warm but the rest of the basement is definitely cool.
The spots are on a "bump-down" area of the ceiling - I cut a hole so I could see what's going on.
The "bump-down" is there because there is a metal I-beam running the entire length of the house and it looks like water is condensing on that I-beam. When I touched the I-beam it didn't feel particularly cold but certainly not warm. There are a ton of warm uninsulated heating ducts running near the I-beam too.
It's been between 5 and 30 degrees here for the past week or so. There is a faint cool air draft coming from the hole I made so I guess I need to add insulation somewhere but I guess I'm not sure how this I-beam ties in to the outside walls of the house and how exactly to insulate it. Do I need to cut holes in the outside walls on both sides and stuff insulation in? Could I just spray insulation from the hole I already made to avoid a bunch of patch work? I can post pictures if it would help. I guess I'm just not exactly sure how to fix my condensation problem.
Thanks!
Thanks!
