Marion Moore
Thread starter- Joined
- Feb 6, 2005
- 200
I have a Suzuki DT115 EFI 1996 with the newest model PTT with the plastic fluid reservoir on the side. The tilt cylinder leaks around the shaft. No corrosion on the shaft so I suspect the cap seal and wipers are bad.
Here is my problem, looking at the parts break down on the Brown?s Point site I am confused as to what seals are available. http://store.brownspoint.com/dt115/fig042-1158601.asp I don?t see a tilt cylinder shaft seal or wipers on the parts break down. Items 3, 10, and 11 are marked as O-ring ?sets? but the drawing only shows one o-ring??? I don?t see a Tilt Cylinder Head / Cap offered. It looks like you have to buy the Piston Assembly for $201 if the only way to get a new cylinder o-ring is to buy the cap???
The last part of my problem is I can?t get the 3 reservoir bolts loose nor can I get the three allens that secure the power unit and pump assembly http://store.brownspoint.com/dt115/fig040-1158601.asp . There is very little corrosion on the unit but when stainless and aluminum meet they love to stick. Because the reservoir is plastic I can not apply heat to the stuck bolts for fear of melting the reservoir and damaging the trim seals.
Anyone been down this road? I may need to call Brown?s Point Marine and find out what seals are really available.
